help on head bolt torque for wc engine
Anonymous-0
What would be the factory spects and would it be different on a puller engine with fairly high compression thanks guys i'm new to the ac engines always run red ones before now.
mlpankey you seem like you know ac engines could you tell me what the factory specs on the bolt are and would a copper gasket help this thing has a lot of cranking compression thanks
i have ran as high as 14.1 on the felpro blue gasket with 4.125 liners. tighten the 1/2 studs and cap bolts to 90ftlbs the 7/16 screw 70ftlbs
