Anonymous-0
I am trying to remove the head off my JD 530. I have all 8 nuts removed and the head is not coming loose. Some of the bolts (studs) still have part of the lead washers that pressed into the threads. Could this be the problem or does the gasket dryrot and help hold thing together? Whats the best way to separate it from the engine with out damaging anything? Also what is the torgue and sequence for the head nuts and the intake/exhaust manifold bolts when I put it back together. Also should I use gasket sealer (like permatex) on the head gasket and manifold gaskets when I put things back together? And any other cautions or tips to make sure I do everything right will be greatly appreciated. Thanks alot in advance...Charles
