Fritz Maurer
Friend bought a tract of land with a 40x40 tin
building . After clearing some brush away we
discovered a gas well about 50 feet off the building.
The well is attached to this huge meter with 3inch
pipe, and another 3 inch pipe coming out of the
meter into the ground and disappears.
So we want to use the well to heat the building
but my friend is afraid of getting busted for stealing
gas, because the property deed, gas company
information and the actual location of the well are all
conflicting information. For instance: the number on
the well is on record, but states the well,s location is
on a neighboring lot. Second, the same google
search produced a yearly production chart, stating
that the well with this I.D. number produced over
200 MCF of gas in 2020. Both valves on the meter
are off. Wouldnt they monitor more closely a well
with that kind of output? There is a tag in the meter
box stating the meter was last serviced in 2005.
The property deed is also unclear in that it only
says the property owner has the mineral rights in
1936 when the well was drilled. Does not say
anything about transfers. The previous owner of the
land has died and can offer no information. Would
appreciate any thoughts on this matter. Thanks,
Fritz
Fritz
