(quoted from post at 02:26:25 10/27/13)
The power steering allows me to use one hand, even with the loader on.
Very intrigued by the addition of power steering. Pixs show only the right side of your tractor with no drag link although I see a pump and tie rod in the last photo. Inquiring minds want to know!
This Jubilee had a Sparex add on power steering unit installed. The kit includes single hydraulic cylinder, new steering brackets on spindle, tie rod, modified front crankshaft pulley, modified water pump housing, power steering pump, etc.
The unit was on the tractor and the reason I bought it. It was probably the only thing really working good on the thing.
More info and pics.
http://www.camplulu.com/tractor.htm
more pics available on request.
Tractors Built 1939 to 1964
SPAREX TRACTOR MODEL
No.
DESCRIPTION EQUIVALENT
Add-on
Power Steering
Conversion Kit
Note: These kits are add-on
units designed for tractors
without loaders. The Cylinder
and/or Tie Rod Assembly may
interfere with loader frames.
1 S.61100 Conversion Kit (Contains: 2-15) 600, 800, 601, 801, 2000, 4000 (Except Rowcrop
Made in USA Gas Models only)
2 S.61085 Pump Kit - Gas
3 S.60371 Spindle Arm - LH
4 S.60373 Spindle Arm - RH
5 S.60381 Drag Link
6 S.60389 Tie Rod - LH
7 S.60388 Tie Rod - RH
8 S.60390 Tie Rod Center
9 S.60391 Tie Rod End
10 S.60483 Radius Rod
11 S.60796 Double Pulley - Crankshaft
12 S.61039 Power Steering Cylinder
13 S.61382 Cylinder Adapter
14 S.61115 Thermostat Housing
15 S.11175 Belt
16 S.61328 Stud - Control Valve
