Tractorcedric
- Location
- Garland. Utah
I have an old backhoe that has a Funk reverser in it. Seams to have a pretty good KLUNK when changing directions. The last time I used it the forward clutches seamed to be slipping. I plan to repair it as well. The brakes don't work that good either. So I took the covers off of the trans and differential. There is about 16 thousandths play in the ring gear. I can see that the differential carrier bearings need to be adjusted as well. I can do that when I do the brakes. If I take shims out on the left side, that should give it less backlash right? Also were could I get trans cover gaskets for this tractor? It looks like a rearend of an Oliver 880 or 770. Thanks
