Tree-Farmer
What's the appropriate tool to remove this broken bolt? This is a hydraulic limiter/regulator from a JD 7100 planter, for the markers.
The adapter broke off, at the top, in this picture, I want to get it out.
It's hollow.
Is there a screw that I can screw in one way, tighten it up against the the broken bolt/adapter, then turn it the other way to back it out?
What tool/screw should I use to remove the broken part?
Thank you!
It's hollow.
Thank you!
