Brown David
- Location
- New Brunswick Canada
Is it this one?
I've had good luck using two hammers.
One on the back side flat of the black nut on the filter and smacking the front side flat with the other hammer, rotating around the filter as much as possible.
Do the same to the nut on the line if it is frozen to the line.
Probably not a lot of room to do that but repeating the process a few times helps.
Maybe that's what you meant when you said you tried banging on it.
EDIT: Jim. ME beat me to it.
