How to replace PTO gears?
I was wondering on how to get this gear out ? do i half to split the tractor in two? thanks for any help.
Which model tractor..??
Maybe not..if you remove the engine first..but, usually it is accepted that it is best to split the tractor..
Ron..
If you take the Hydraulic pump off and take the cove off the hand clutch you can slide the shaft out and change the gear than slide the shaft back in.Its not really that hard just take your time. Make sure the hole is in the correct orentation before slideing in or you will be sliding it back out to get the keeper back in. I think it took me 4 hours to finish the job.
