I just cant figure out the Fluid levels for the shuttle ? So it is basically a AC 615 which is a D 15 industrial , later model so its a 2nd
generation with the 200 cu diesel with backhoe and loader. It has a simple geared 4 speed trans and clutch . there is no reverse using the
top shifter as what I read in the service manual the trans just has the two rails inside it and not the top 3rd rail so reverse only comes
in when you pull the shuttle arm back in reverse .So there is 2 dip sticks , one is above the trans/rear end cavity and then one above the
shuttle cavity that is in the rear end of the torqe tube . As far as hydraulics it has a front mounted pump for the backhoe and the loader
and they both use the frame of the backhoe and loader to store the supply on hyd fluid. it appears that the rear end /trans fluid is shared
and then the torque tube houses the flywheel/clutch/pressure plate up front and in the rear a cavity for the hyd shuttle and power steering
pump. and it has a seperate dip stick above that area which makes me believe that evidently the trans/rear end / final is 1 fluid probably
a trans fluid and the pump in the torque tube for the hydraulic clutch/and power steering is a seperate area not sharing the same fluids .
So I checked the rear fluid for the trans /rear end which is on top of the trans and it was really clean on the dip stick , justv a litle
less than full so I added trans fluid , how ever the dip stick above the torque tube under the gas tank did not show anything at all . so I
want to add fluid to it but I can not figure out what is stamped into the dip stick ? it does not make sense . here is a picture of the
dip stick for the shuttle pump area . I just want to fill it up with hyd fluid to the correct level but for some reason I dont know what
this means ?
this means ?
