Skeeter102
When using my 8n I've noticed that i get some weeping out of the fill hole on the transmission cover from underneath the cap. I have also noticed that I will get hydraulic fade when the tractor is warm. The hydros aren't as responsive at idle when warm as they are when cold.
This is central Texas and its been in the 90's while running the tractor. I've mostly been using the box blade to build driveways.
The fluid is new, pump was dropped and cleaned, and all linkages are aligned properly using zane's jig. I have a new top cover gasket, and NAA lift piston with leather and rubber washer.
I am using traveller UTF that meets the 134D spec.
What's up with this?
