Turkeyfoot
Spent thus afternoon chasing an intermittent electrical problem on 83 mustang. Mustang starts and runs fine most times. But has on one instance lost power while driving. And other times will not start after running. That is you park it then go inside and then come back out and it won't start. When this happens power to gauges comes on but the tach does not respond while cranking and there's no power to the ignition. Today we replaced the switch in the steering column that's activated by the rod from the key mechanism. See photo. When it's having this intermittent problem it cranks but with no start, and when you turn the key from start to run it will briefly fire as you turn the key but won't start. All ignition components are fine battery connections are fine. Everything works and the problem seems to be in the steering column. Any thoughts?
