Ignition switch for A/B
old
So I have this BA I built years ago from an A and a B. Yesterday I got it out after having to mess with the points etc. Had to hot wire it or it might run or it might not. No bit deal to me to hot wire but that my not work for others in the future
A regular ignition switch with battery (distributor) ignition is part number 62801DC,
Steiner has them, their part number is IHS382.
As old well knows, YT sells parts, no need to advertise for Steiner. He will likely keep going with the jumper wire as he likely has one tucked away somewhere or in another parts unit.
At my age and what little I use this tractor I'll probably stick with the hot wire I have it set up so I can reach it from where one sits on the tractor so easy to disconnect it. Yes I'd like to replace the switch so others can use it when I can no long use it
