I'm sure I am making this all out to be more complicated than it has to be. Is there a wiring diagram for this tractor? Do the hydraulics even operate electrically? I can frame a house, but this is all foreign to me. I cleaned out what I thought was the hydraulic filter, but no luck getting them to move. They were working fine when I went to purchase it and that was when they had no fluid in the reservoir. Now, it may come as no surprise that the wiring that is on this tractor has all been rigged up by the previous owner and is a hot mess. I need to replace the battery terminal cable for sure, but there are also 2 other wires leading to the positive terminal that are all bare wire and just...not done properly.
The only things that have changed since I got the tractor home is that I added fluid, and I have to wiggle the existing wiring to get it to start up. The problem has to be related to one of those things. I'm thinking it's electrical because of screwing with the wires. Maybe what I found was not the hydraulic filter so the plug is still in there stopping things from working. The reason I suspect it's electrical is that now the hydraulics won't move at all, they won't even try whereas before they would at least jump a bit and try to work. Again, messing with the wiring that is poorly installed I think has caused this issue. I can get out there and take some photos today to show you what I'm talking about with the wiring so you too can scratch your heads and say "what in the world...?"
Anyone have any thoughts?
