K95150
Hi, just picked up a 1976 IH 674 Diesel, europe model according to serial # It's great, question I have is on the lift levers. Sitting in the seat, the outside lever raises and lowers the arms, I have a brush hog on it now. The lever next to it doesn't do anything? From what I've read its supposed to stop the arms at which point you want? to control the height of he brush hog or other implements? any help or suggestions greatly appreciated, or if somethings wrong how to fix.
Thank you
-G
Thank you
-G
Put the draft control lever all the way up or all the way down, and then move the position control lever and see if that makes a difference. Can't remember which way the draft control lever has to be for the position control to work correctly, but it has to be all the way up or all the way down.
At least try that first...
Not to sound dumb, lol but which one is supposed to be the draft control? Inside or outside lever?
Thanks
-G
Inside lever is position control. It should raise and lower the hitch no matter where the draft control lever is. The draft control does two things, bepending where you set it in the quadrant, for example, if plowing the draft control will only allow the hitch to lower to a certain depth on where you set the lever no matter how low you set the position control. This means the hitch lowers to the same depth every time after you raise the plow at the end of the field. The draft also senses the load on the torsion bar (third link). If the load gets to heavy it will raise the hitch to ease the load momentarily then go back to the preset position
