Michaelr0953
Hi folks I have a 2002 John Deere lawn tractor that I am have an issue with the rear tires leaking through the side walls, I am sure it's the age of the tires, they have great tread, not cracked as bad as I don't believe it would pitch the tube and I am reluctant to change them when I can just put tubes in him and cure this issue.
My concern is where the valve stem exits the rim, our local tractor supply just sells straight stem inner tubes, as in the photo you can see the valve stem exits side of the rim. Not sure if the run-of-the-mill inner tubes will work in this application
Any thoughts on this would be appreciated.
![cvphoto603.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto603.jpg)
