MarkB_MI
- Location
- Motown USA
For LONG TERM storage, consider dessicant plugs in the spark plug holes.
Engine dessicant spark plugs
''The only way i found to fix it was to use it. Now we don't run it hard but we simply mow about half an acre about twice a year nothing crazy just some pasture.''
BEST answer yet!
(quoted from post at 14:14:36 09/24/23)And no sort of extra oil flow nor any sort or type of PCV valve will do anything to remove condensation without running it.''The only way i found to fix it was to use it. Now we don't run it hard but we simply mow about half an acre about twice a year nothing crazy just some pasture.''
BEST answer yet!
If you refuse to run it up to 180 degrees or so for an hour or more once in a while, your PCV valve is useless. Once in a while is more than once a year.
An hour in spring when temps are consistently in the 70s or so during the days and again in the fall before freezing weather.
PCV valves were to help burn off crankcase fumes of unburnt fuel to reduce emissions and maybe burn off the moisture.
And it won't burn off moisture unless it has vaporized due to RUNNING it up to temperature long enough.
Maybe you need one of those giant plastic bags you can drive a car into. Put a bucket of DampRid inside and seal the bag using your shop vac!
