Christian Verville
I bought a JD 1830 and the guy before me had a supply line from the pump runing a log loader on a power trailer and the return line is going back to the filter. When the log loader is not used the two quick connect line are left disconected. Now i started to use these line to run two hydrolic motor on a feed table to supply my firewood processor(run by the PTO on the tractor)whit a open center 4way joystick. i couldn't even touch the hydrolic line or fitting they were that hot. the transmission temperature was 210 degree celcius (i check with a laser termomiter). Since i have change the control valve to a close center but i am starting to second guess myself and im worry that it will damage the pump on the tractor. let me know what you think. Thanks
Chris
Chris
