Why would you think the pump is 180 out? Has it been off? Has it been taken apart and reassembled? Any other work done to the engine? The whole story can help find the correct answer for your problem quicker.
Sure, if you're careful. If engine has banjo type injection line outlets remove number one line bolt. Turn pump to align timing marks under the side cover, then blow some air in the pump port to clear out some fuel. With a light look in that port, you SHOULD see the rotor outlet port on that cylinder, it may not line up exactly, but should be visible. This confirms the PUMP is assembled right, IE weight retainer on correctly. Next with the valve cover off, the valve rocker arms on number one should BOTH be loose. If they are on the exhaust closing, intake opening overlap position PUMP is out of time 180 degrees in relation to engine..
You need a way to determine when #1 cylinder is at top-dead-center on the compression-stroke. Easiest way to tell is to take off the valve cover and look at the rocker-arms. If an injector could be pulled, you could tell by compression pressure - but those pencil injectors are usually very stuck.
