I have the 2 battery boxes and have worked through a bunch of slow cranking issues with you all.
I am currently using only one of the TSC 400 some odd CCA batteries to start. I used to have them hooked up in parallel but in the summer I reverted to 1 battery and it cranked pretty well. Being winter now it is cranking a lot harder. I am going to install a destroker on the PS up front...but if I hook both positive cables directly to the starter will I get 2X the CCA's and not cause any damage?
Also, would I connect each battery to ground or neg to neg to ground?
