JD 620 not starting
NY620
I was trying to get my 620 in to the garage so I could change the oils for this spring and summer and when I went out to start it it would not start. I got it towed around and in to my garage space and thought I would let it thaw and then it would start but still no luck. It was running this past fall.I have checked my spark and I have spark, checked the carb and that"s allowing fuel through it and the air cleaner has the proper amount of oilf in it. I just did a compression test on it and one side was 90 and the other side was 115. I"m starting to run out of ideas of were to go to get it started. Any suggestion would be greatly appresheated.
If you have gas and spark, perhaps the sparkplugs are fouled/shorted. Try another set or (BE SAFE) burn them clean with a torch and try again.
did you try pull starting it, if it will start that way, and run ok, then check the resister, and the start wire going to the starter.
I've got 2 620's and they can be tricky when they don't want to go. To much choke and it takes forever to get them going or not enough and they won't go. My loader one will only start if I push the throttle ahead a little and give it a short choke. When it's warm of course you don't want to choke it or it won't go either. If battery gets low they won't go either. Pull it 3 ft. and it will run.
And I thought it was just my 620 that was a finicky starter. If I don't have things just right, it can be very difficult to get going.
Coil polarity? Is there a 6V 1.5 ohm coil on there or a 12V 3.0 ohm coil? Is the starting bypass circuit working?
Is the voltage to the coil dropping so low during the compression stroke that the spark isn't strong enough to jump the gap?
Battery, cable size and condition? Is the chassis cable bolted to the side of the battery box? Which is thin rusty or painted sheet metal thjt doesn't carry power without vd??
My GAS JD 630 used to give me trouble at times, until I got to depressing the button on the top of the automatic fuel shut-off for about 15 seconds..
Then, it Jumps to life with full choke and just a little throttle..
Ron..
