I have a JD2010 with the MS TSX 810 N61 carb. I put the rebuild kit on it and thought I did a good job. Also did new spark plugs, battery, and fuel. Pulled the choke knob out and it started right up. Sounded better than before. Pushed the choke knob in about 1/3 and it began to sputter, at half back in it was going to die. Pulled the knob out and back to sounding good. Revved up fine, too. Pushed in the knob and it began to sputter. Turned it off and I moved the air intake away and felt the butterfly plate. Knob full out and plate is closed. Full in and plate wide open.
On the rebuild kit it said to use everything but I didn't. Didn't use the choke plate shaft or the felt bushing. I've no idea where a felt bushing should go. Also, the float needle looked too different and didn't have a way to attach that spring clip on the original, so I stayed with the original float needle after polishing it.
There is also a brass shaft through the center that I sprayed clean but didn't try to remove. It looks like it's been filed on a bit from a previous repair.
I'm not sure where the adjustment screws should be.
I used the gasket that came with the kit but didn't use a sealant on the gasket.
So, any help appreciated. Thanks, David
