I bought a JD H with the engine in a basket a couple years back. Getting over the whole thing, have inspected every part, replaced EVERY gasket on the tractor and EVERY seal on the tractor except the bottom bolster seal (if there is one). I went through and overhauled the engine, did the head work, etc. The tractor came with a new head set, although it was quite old, probably 20 years old, but all sealed up. Can't remember now, but I think it was a Felpro set. Anyway, when I put the head on, it came with copper washers instead of the lead washers. So, I used the copper washers. I work on this project when I'm waiting for parts or something for everyone else's stuff and have a few minutes, so it mostly sets in the corner until I can get a few free minutes. So after I got it all back together, torqued, push rods in, and adjusted, 'valve cover' on, filled with oil and all galleys full, radiator on, and filled it with coolant, after about a month of it setting there, I see a couple drips of coolant under it. I go look it over and it appears that coolant is coming around all or most of the head studs. Not sure about the ones under the valve cover, didn't crack the oil plug or take the cover off yet, it's not a real high priority. I'm just assuming I should have used lead washers instead of the copper ones it came with???? I haven't even started the engine yet, but I figure either way I'm gonna have to pull the head back off and replace the headgasket and then use lead washers instead. Isn't that their purpose, to seal the coolant from doing exactly what mine is doing and coming around the studs? I don't remember if I did or not, but I'm pretty sure I pulled all the studs and put sealer on the block end, probably better check those too. Also, what is the proper way to install the lead washers? Do you grease them at all? Now I don't work on many John Deere's but I've rebuilt a few 2 cylinders, it's just been quite a few years, but it always seems like when you torque the head nuts, that the lead washers appears to, many times, almost completely be torn to shreds or exuded from out under the nut. Maybe that's exactly how it's supposed to work, but it just seems like most of it is gone out of there once it's torqued. Sorry for the long post guys, just aimlessly thinking about it while waiting for the wife to finish getting the groceries and get out of the store, and figure I oughtta button this thing up and get it done. I've got the next 11 days off from my 'real' job so I'm trying to get as much done as possible.
Thanks again
Ross
Thanks again
Ross
