JD420 shimmy on hiway at hi throttle
boler76
can shimmy be cured by increasing toe in, it is set at 3/8 and all tie rods are tight and steering box has negligible play?? thanks
I can't tell you about wear on tri rib tires, but 3/8 toe on your pickup will git you new tires in 5,000 miles. I agree check for a well worn, worm gear.
as bob barker would tell his contestants in the game, holler that too much! on any vehicle a shimmy is tire out of balance. on a tarctor it is not turning fast enough. so u must have a loose steering box. at least its not a death wobble like the dodges have. toe in is 1/8 imch. better get it back into spec's. definitly nothing over 1/4 inch. and what are u meaning by shimmy? are both tires flopping to the right and left. then when u slow down it cures itself.
Nobody is looking where 90% of the shimmy occurs .
The half moon key and the key ways are wallowed out . Steiner sell new collars to weld onto the steering shaft .
you sir are the owner of a well used tractor. tie rod ends,loose gear box worn key and key way loose bearings
How fast you goin' ? 55 to 60 is a little fast for any tractor. We had a Grand Haven sweeper at the township. It was a tricycle and had a mean wobble at speed. I made up brackets and added a steering stabilizer to it. Worked great.
(quoted from post at 21:05:19 08/05/23) can shimmy be cured by increasing toe in, it is set at 3/8 and all tie rods are tight and steering box has negligible play?? thanks
Steering box adjustment ?
Have you checked the fore /aft play on the axle pivot? Our 40U had 1/8" or better and it sure sent the front wheels into a "dance" while in road gear.....
As previously mentioned play in the woodruff key on the steering shaft and gear box wear / adjustment will contribute as well.
(quoted from post at 18:05:19 08/05/23) can shimmy be cured by increasing toe in, it is set at 3/8 and all tie rods are tight and steering box has negligible play?? thanks
