I Finely Got the loader lift problem figured out. The steel ball in the relief valve was not in place.
Now I have lifting power, so I think the loader is working fine now.
I still have Hiccups in the rear 3 point lift I would like to fix. can you give some insight what I should do.
I believe it would be the O rings on the lift piston? IH 283 ind. same as a 384 thanks oldiron29
