All right. I got an open station 2355 a few years ago for bush hogging my hilly 30 acres. It's 2wd. This past weekend I was exiting the field and when I engaged the clutch I rolled a few yards and there was a pop. Then I could no longer engage the clutch and tractor stayed in gear, only way to stop was to pull the kill switch. As much as I played with clutch it never would engage, so I limped home in low 4, killed, reversed in 1 to put in barn. Is this a creeping issue? What could be wrong just a stuck clutch, pilot bearing or do I have something else going on? Looking for input to see if it's something I can take care of or do I need to call a mechanic to split and fix? Before that everything worked great, was downshifting to because of the steep path.
This post was edited by Cwhitney on 05/02/2022 at 03:14 pm.
