Glen D Anderson
Good day!
In the process of overhauling our 40U and going through the governor / carburetor linkage adjustment I've run into a bit of a snag. When trying to adjust the carburetor to governor rod length as per the SM I find that the rod appears to be too short.
With the throttle lever in the WOT position, adjust the rod until it just slips into the carburetor shaft arm which is to be held forward(WOT position) and then thread the rod into the ball joint 2 additional turns.
Well, as per the attached picture, the rod on this machine isn't even engaged into the ball joint(unless I pull the governor arm rearward against spring pressure). Looking closely at the end of the rod(90 bend) that connects to the carburetor arm it appears to have been repaired / reworked so I was wondering if it somehow got shortened in the process? I never paid attention to whether there was tension on this linkage when I took it apart well over a year ago so I just don't know...LOL
Also, you may note the new ball joint in the picture. It is dimensionally the same as the old one and I did notice it was only threaded onto the shaft 2 - 3 turns leading me to further question the rod length?
Thoughts? Anyone have a spare rod laying around they could measure? LOL
TIA
TIA
