John Deere H
I just got what is belived to be a 1939 John Deere H from my uncle. It has set outside with the cultivators on it since 1980. It still turns over, but otherwise it needs everything. I guess the first thing I wanted to find was a used set of rear tires for it so I can move it around in my barn while I'm working on it. They are 9-32, if anyone has an old set sitting around they arent using that would at least hold air, that would be great! I'm located in Michigan, but can travel, thanks
Dale - You might also try putting a wanted ad in on this website - they have been pretty effective. Watch eBay too -- not much there lately, but timing is everything and you may be Blessed!
You can learn a pile about the "H" tractor by visiting the John Deere Model "H" Restoration site listed below. And if I can answer any questions for you, feel free to write or call. (PatB @ 386-624-7916).
Restorat ion Site, JD H
The last thing you need is tires. You can drag them around on the flats or even on the bare rims and won't hurt them unless you lift it up and drop it. Even then you can easily straighten them out.
Save your money to get it running first or at least until you can open it up for an ascesment you may find too many things wrong inside and have to part it or use it for a donor tractor.
