I recently purchased a Gleaner K2, my first combine, and have a few questions. I have been lurking for a while and have found a wealth of knowledge here so I am sure you guys will be able to help a beginner like me.
I have three issues that I have not been able to get adequate information from my operator’s manual.
1 – I replaced the main drive belt according to the instructions in my operator’s manual and it is slipping. How much play should that belt have when the tension pulley is adjusted properly?
2 – The hydro temp light in the overhead consul is coming on when I run the combine. The buzzer is not coming on, however the light is. Right now I do not have a head on the machine and the light will still come on. I have not done anything other than make sure the fluid level is good. Any suggestions as to where to start?
3 – Finally, I cannot seem to figure out how to lock the steering column in place. It moves back and forth and the latch it shows in the operator’s manual is not working. Any suggestions how I can lock it in place?
Thank you in advance for any information you can give me.
Scott
Scott
