klampero sharpener
Has anyone on here bought one of these much advertised KLAMPERO chain sharpeners... i find they want half price for them on amazon...
Another gadget, read the reviews. A good file guide (the type the file mounts in) and the correct file will do better from what I see. Clamping the bar in a vise or other method of holding it from moving as you file helps.
I bought a Harbor Freight Grade sharpener. Looks/works like a professional grade Oregon, plenty good enough for the chains I sharpen. Quick, accurate and consistent, beats the daylights out of any manual filing system.
When necessary, I'll chuck up a sanding disc in my right-angle die grinder to touch up the rakers.
I have a powered sharpener too, can't remember the brand but it works great when the chain needs a sharpening because I hit something with it. Otherwise I just use a file. After all these years I can do a pretty good job by eye. 👨‍🌾
I have a cheap HF power sharpener to save a damaged chain but the rest of my sharpening has been freehand with a file. My wrists and hands are worn out and file sharpening hurts. What I found to make it easier on my body was the 2 in 1 style sharpeners like the Stihl. Much easier to hold then just a file, I do clamp the bar in a vise.
I use an HF grinder on a badly beat up chain, but it takes off a lot of metal to use for every sharpening. I use a stone in a Dremel tool for routine sharpening.
While that is true, I use mine for every sharpening because I never can keep the angle(s) consistent while hand sharpening. Also, my shoulders and hands are not a fan of repetitive motion.
Then again, don't use a chainsaw much any more so even with the aggressive sharpening, they last quite a long time.
I gotten a lot of life over the years with my chains just using a hand held die grinder/dremel. Having angles the same and teeth the same length is nice, but not critical. This chain would still trow 1/4 inch chips when sharp before I retired it.
That's how the chain on my little Echo looked before I hit something in a tree. It locked up the engine so fast, I suspect it sheared the flywheel key, I know it stripped off 3 chain teeth. Never have gotten around to repairing it, since I bought the Ryobi electric saw.
