Anonymous-0
power lift is erradic dept control and position leaver has to be moved mid was before lift will work
pressure on pump a little weak but will lift plan to take top cover off and check adjustments any ideas about adjustment procudure
Before you take the lift cover off, take a look thru the right inspection port with the tractor running and attempted to lift a load. That will show you were the leaks are. Usually from the piston, but the pres relief valve or any of the gaskets can leak. The I&T FO4 manual is very useful in guiding you thru this. Also Zane Sherman make a jig and instructions for adjusting the linkage.
Zanes site
