TheOldHokie
- Location
- Myersville, MD 21773
I would say thats your valve but uou need to know a bit more about how its configured. I am sure it can be setup for closed center operstion which would deadhead the pump against the relief and cause a lot of heat. There is a "plug" in the side next to the tank port. Take it out and see if it is a closed center conversion plug.1 Spool 30 GPM Double Acting Directional Valve Cross Mfg 131135 BA11AG3EA0 SBA2 | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
1 Spool 30 GPM Double Acting Directional Valve Cross Mfg 131135 BA11AG3EA0 SBA2, Directional Control Valves, 1 SPOOL DOUBLE ACTING DIRECTIONALCROSS,131135,www.surpluscenter.com
This looks almost identical, might be an updated model of the valve?
Cross Mfg BA Series Closed Center Plug 1V0206 | Cross Mfg | Brands | www.surpluscenter.com
Cross Mfg BA Series Closed Center Plug 1V0206, Cross Mfg, CROSS BA CLOSED CENTER PLUG To convert Cross BA series valves to closed center. Shpg 1/2Cross Mfg.,1V0206,
Dan
