TheOldHokie
- Location
- Myersville, MD 21773
Way too hot. You need to get more info on thst pump. Do a simple flow meaurenent:Used the splitter all day yesterday, must have been above 30 Celsius outside and the oil reached 220F. Cylinder started leaking at the rod more and pump sounds like it cavitates once oil is warm. Pump is quite when oil is cold, pump is quite when valve is in action in either direction once warmed up. Still no pressure gauge. Engine is throttled down to almost an idle. Oil still looks like it did even after hitting 220F
- Get a clean 5 gallon bucket and mark the 3G level on the side.
- Disconnect the hose on the base end of the cylinder and put the hose in the bucket
- Start the engine and set it to idle.
- Move the lever to max extend and time (seconds) how long it takes to fill the bucket to the 3G mark.
GPM = 180/seconds
TOH
