massey 200 loader valve ?
jbc8000
Hi i have a mf 200 loader on my 165 for about a yr or so now. My ? is, can you use both levers at the same time on these. Lift and bucket, mine is either one or the other. Is this normal or is there something in my valve thats not right, and can be fixed. thanks
Some valves work at the same time and some don't. Try lifting slowly and see if the bucket will tilt at the same time. If not your valve probably isn't designed that way. MF had some valves with selective self leveling. If you pulled the lift valve even further than full speed it directed oil to tilt the bucket at the same time. Dave
Yes the bucket will self level when pulled back all the way. So my operation is correct then only one or the other? thanks
Most likely you don't have enough oil flow to operate both smoothly by hand. Do you have a separate pump for the loader or does it use the internal hydraulics, because if so, I'll bet that is the problem. MK
loader is set up with front mount pump and using the arm as the holding tank, operates smooth and has plenty of power. Just wasnt sure if this was a valve issue or just the way they were made to work.
