Hi all,
This might be better posted in the Implement Alley forum, but perhaps it's ok here.
I have a Massey 555 with the garbage JD382 that's been giving trouble off and on. Pulled the head off this winter to find a very worn
engine with cracks between the sleeves (not too concerned) and in the head (slightly more concerning). I was going to rebuild it, have the
block furnace brazed and the head fixed, but the rebuild parts for these are ridiculously priced and hard to find. And, if I did rebuild,
I'd still have a 382 - not ideal for the sawmill/threshing work I use it for as it's an unbalanced engine, and an engine that has an ok
reputation at best.
I have a Detroit 3-53 power unit that came with one of my circular mills that I've since converted to PTO. It has a hand-clutch on it. I
know a repower is a pain, but it seems like the ideal candidate to drop in and make this a usable tractor. My only question is regarding
the hand-clutch: I have no problem fabricating/machining linkages and parts to make this work with the clutch pedal, but I don't know if
the clutches in these power units are suited for the more frequent stops/starts you get driving a tractor around. If anyone has any
thoughts/experience on the matter it wold be greatly appreciated.
I know Centash had a 3-71 in a 55 which I asked about a few years ago. If you happen to see this, did you have any problems with clutch
longevity?
Thanks kindly,
Daniel
reputation at best.
longevity?
Thanks kindly,
Daniel
