My 3 point does not work properly. I painted the tractor and during painting I removed the bolts from the quadrant lever plates. One of the levers
rotated downward. At that point I realized that removing the plates would rquire more disassembly than I wanted to do. I rotated the handle that
fell down back into place and replaced the bolts. When I finished painting and assemling the tractor I cranked up the motor and tried to move
the 3 point hitch upward but it would not move, it did however move with the draft lever. Needless to say the hitch is not properly functioning. I
am thinking that when the left lever rotated downward, something must have disengaged inside the hydraulic lift cover. I am hoping one of you
could give some insight on that, I dread the thought of having to remove the lift cover not knowing much about it.
