logan.ambrose22
Ive got a Massey Ferguson 180 multipower serial number 9AII573. Regardless of if Im in high/low range or high/low multipower, whenever im moving up hill the tractor will slow and come to a stop for up to 10 seconds before it starts moving again. It just has no power when moving even up the slightest slope. In the lower range/gears it will keep moving, but you can tell its struggling. I replaced the multipower/transmission filter (the one in front of the radiator), it did have some metal shavings in it. I also replaced all the hydraulic fluid. The multipower switch is engaging. I can feel it engage and slow down or speed up. In high multipower, it engine breaks going down hills. The auxiliary hydraulics seem to working, as well as the three point. Is the hydraulic pump bad? Or could it be something else? If I need to split it, thats fine, I just dont want to split it if it could be something else. Thanks everyone in advance!
