Hello,
I have the MF 150, with a Perkins 152 gas engine and recently had the starter rebuilt. Being an idiot, I didn't take a picture or write down the original wiring, and I thought it would be easy to remember. Well, some were easy to remember!l.
I also have the manual from Yesterday's Tractor, but it doesn't have all the wires that the tractor has on the diagram.
I have these wires (below), and where I think they should go, if you're familiar with the MF 150 wiring of the starter, can you correct where I've got them wrong?
Heavy Red (large hole on metal bolt on metal clip), the Main Starter Terminal.
Heavy Black (large hole on metal bolt on metal clip), Main Starter Terminal.
Light Red (large hole as if it's for the Starter terminal, but doesn't fit the starter terminal). I'm thinking it goes to the "R" terminal on the solenoid? This is the one that's got me stumped.
Light White (may have been yellow at one point, it comes from the Neutral safety switch). Goes to the "S" terminal.
My carburetor "Fuel Shut off solenoid" has a wire that goes to the Starter as well (that one I remember going to the starter). I'm thinking that it goes to the "R" terminal on the starter solenoid.
My understanding of the "R" and "S" on the solenoid is that "R" is for "Run" for when the tractor is Running, and "S" is to Start, and is only "hot" when the key is held in the start position.
Thanks in advance for any help.
Curt
Curt
