hellothere123
Thanks for your help.
Battery and ground ok.
Getting 16volts to solenoid
Push the start button, solenoid click but doesn t turn starter.
Battery now at 14volts.
Recharge battery.
Tried to jump solenoid with screwdriver. Spark but starter won t turn.
I ve had intermittent trouble with the neutral safety switch, but will wiggle the shifters and it usually starts.
Question is if I have a bad neutral safety switch should I still be able to jump the solenoid? Or does the previous attempt mean it s gotta be a bad solenoid?
Also is the neutral safety switch behind the dash? And if so can I jump it to see if that s the problem?
Solenoid is only 2 years old. Just replaced it.
Thanks for your wisdom
Recharge battery.
