I haven't been around too many MF's but I am currently working on a MF 50 and upon removing the existing clutch dual clutch (Serial # S6M 537762, 4 cyl. continental gas engine) I noticed it was covered in oil. A few questions I have are:
- How do you change the rear engine seal. It looks like only the top half I can take off since the bottom bolts appear to be in the other direction. Do you have to take the oil pan off to change the seal (not a rope seal)
- How do you change the seals in the power input shaft. Do you have to remove it and take it apart to put them in from the back side?
- What type of oil and how much does the rear end take? I am assuming they used 80W90 gear oil in the rear end of these?
- The valve on the top of the transmission housing (push/pull lever shown) leaks constantly. What is the best way to fix this leak?
Sorry I do not have a service manual and am not that familiar with these tractors. Thanks in advance for all of your assistance.
