allen in texas
It's gonna work. I just need to drill 4 more holes
(quoted from post at 02:47:59 12/23/12) Looks live a 6341 plow. We sold several of those here in flat Northwest Ohio. FYI for you. When you get your cylinder you may want to add restrictors to each port. Oliver recommended this to control the speed of the roll over. Can you lift the plow?
(quoted from post at 16:17:12 12/23/12) Allen I have a few questions??? Why did you have to drill any holes??? I have switched 5 or 6 Oliver/White plows from one width to another and it was just moving things to the correct bolt holes that where already in the plow beam. In you first posting before you had done anything you showed the top of the beam and it had the three sets of holes that usually adjusted them from 14,16,18 inches.
Also on the regular plows I adjusted you left the front plow bottom alone and moved each one back closer. It looks like you did it the other way. Is this because it is a roll over plow? or did you go the wrong way???
Maybe Delta Red can answer me as he has had roll over plows for years. I always wanted one but they are not very common around here.
One local dealer did have a fully mounted six bottom roll over. He got it in a dealer close out deal and had to take all the new equipment the other dealer had. We never did figure out what kind of tractor would pick it up. We tried a White 2-180/MFWD with a full set of front end weights and it would stand straight up. He finally just used all the bottom parts off of it a scraped the rest of it.
(quoted from post at 19:40:53 12/23/12) I would buy shear bolts a dozen or so at a time.I mounted a small toolbox on the 'headstock'.kept bolts/nuts;wrench,ratchet/socket;tapered punch;hammer,etc.Carried a sledgehammer in the cab.Even when the 'tripped' bottom was returned to 'home',it always require a few raps with the sledge.
I went to tremendous effort to add all of the coulters to the Ford. Don't really need them here. Not a lot of trash to cut through. Not sure I'll add the coulters to this plow. If I happen to run across some, I may use them.(quoted from post at 11:10:21 12/24/12) Coulters to be added later?
