I have a Sitrex SM180 finish mower. The one belt came apart and part of the cords wrapped around the gearbox shaft between the housing and the pulley.....and oil was leaking out. I'm not sure if it was from pressure on the seal or the seal is damaged. I removed the gearbox and all the pieces of belt wrapped around it. The seal looks to be intact but scuffed up.
My problem is there is a big internal circlip with no holes for a removal tool, that I need to get out to replace the seal.
How do you remove these rings?
Are they replaceable? I need the seal and possibly the ring if I have to some how cut it out.
Any help would be appreciated.
