Trying to static time and wondering if anyone knows where factory placed the distributor. This came with tractor, so I don't know if it's original. It has the FoMoCo tag on it and the oiler tube. Cap has #1 embossed on it.
I suspect the oiler tube should be either 3 O-Clock or 9 O-clock, but don't know for sure. So that's one question. Someone here in the archives said #1 should point to #1 spark plug. If true, coil terminal wire & Cap spring hold down allow the distributor a small amount of rotation due to proximity to Tappet cover.
Another is this. When I insert the distributor, the tang on the rotor is almost past the cap terminal when I use the audible VOM and rotate to where the sound stops (Points opening). Pretty sure that's where one would static time it ?
Both the owners manual & Shop service manual say set flywheel to 8 BTDC which I've done. What am I missing ?
Any help for the illegitimate child NAA ?
