So, I've lurked and read a hundred posts on painting and parts prep. Lots of great ideas, but to follow some of the best practices for each stage is not only slow, it would take forever to get the tractor painted!
So, here's the list of steps I'm taking:
1. Electrolysis bath to remove paint, rust, grease. (this works GREAT!! As an engineer I love using science to do the grunt work)
2. Wash parts with fresh water while scrubbing with scotch brite pad (in the yard)
3. Spray down with rattle can degreaser (brake cleaner)
4. Wipe down part with clean shop rag (Scott's Rags)
5. Rattle can etching primer on paintable surfaces
6. After 15 minutes, WD-40 on non paintable surfaces (inside of valve cover ,for instance).
7. Store part on shelf until time for final paint (up to 6 months)
8. Pull parts for paint day
9. Degrease parts with rattle can degreaser to remove WD40 overspray
10. Scotch brite parts for sealing primer
11. Spray sealing primer, 2 coats
12. 320 grit after primer sets
13. Enamel with harder topcoat (2-3 coats)
14. Allow parts to cure 48 hours inside before much handling
15. Assemble on tractor
Ok, so here's the issue. I work a day job, and can clean up 2-4 parts after the kids are in bed. Not realistic to set up the gun to spray primer for 2 parts, then do cleanup. I need to batch parts to a point where I have a full Saturday of paint work. So, are there other processes I can use to get the results I want?
My key issue is that I need to stabilize parts after the soda bath to keep them from rusting. I'm in central Iowa, 60% humidity is the norm. Parts out of the bath start rusting within 60 minutes.
Posters on here are very critical of rattle cans for any paint work. What's the best alternative (if spray gun isn't an option) while I'm slowly cleaning up parts? I'm open to alternatives.
I'm considering WD40 for all parts in storage, and just do batch cleaning before prime and paint.
The overall goal is a 95% restoration. Engine is going to be pulled, and virutally every part will be addressed individually. It was my grandpa's tractor, and I'm an engineer. It would kill me to do less than an engineer-ish quality job! =)
Thanks for any input!
IowaAndy
PS www.1936farmall.blogspot.com is where I'm keeping a journal of the progress...
1936 Farmall F20 Restoration
IowaAndy
