J Wendt
- Location
- Zumbrota MN
It's easy to hit a post. We probably all done it. I have many times, my own . Don't blow a cork If you tell him I bet he will replace it. Don't let it ruin your life.
If he's like the BTO near me, who farms about 7500 acres, about half of his acres are near the suburbs.I can see this happening farming in the suburbs, but with 10,000 acres, what’s he doing up against the property line?
For one thing, it's not 10,000 acres in one giant field. We have no idea how large this field is or what shape it is. Small odd shaped fields, large equipment, and inexperienced operators are a breeding ground for mistakes. The important thing is the farmer fix the mistake.I can see this happening farming in the suburbs, but with 10,000 acres, what’s he doing up against the property line?
About 2.5 miles.Splitting hairs. How many miles long will that 3’ strip have to be to make 250bu. corn?
My calculator says 2 3/4, Assuming 250 bu/acre corn.............................................................YMMVAbout 2.5 miles.
Xwhatever, I would be talking to the neighbor not the renter. Driving an iron below grade is also a great idea.not venting here as I know things happen.
neighboring fields are rented out to a big farming operation (10,000ish acres). when we bought the property it was parceled off so it had fresh survey markers. our parcel was partially farmed before and is a bit odd shaped so to protect the markers I put in treated fence posts so they didn't get plowed up/damaged.
of course what do they do? they plow up the post. but somehow they missed the survey marker pin by inches but the post is sheared off at ground level.
is it a big deal/end of the world? no. should they be more careful? YES. do accidents happen? Yep.
I have not called them yet to talk to them about fixing it (I'm sure they are very busy right now). Yes, i could go buy another post and put it in. but i'm getting a "bit" older and tired and really don't feel like digging the old one out and putting a new one in, physically speaking, as that is some work. plus if i don't say anything the farmer won't know it happened (who ever was driving knew it happened as they put the white plastic pipe back in place) and won't remind his guys to watch out.
My expectation is they replace the post with new and install it or pay someone to do that. I don't think that is unreasonable. THoughts?
thanks.
I agree dwf. It's not all about the 3 ft. It's the principle. If that hired man can't keep that 60 ft cultivator where it belongs then get a different man or give him some training.I have a new farmer next to my property that my house is on. This spring when it was sprayed, my grass got killed about three feet, OK, but my house is close. When they sent the field cultivator to prep for planting, he saw the dead grass so that got worked up and seeded to corn. Now I should talk to someone to get this nonsense corrected. I have been here 7 years and the other farmers never sprayed my grass or tried to farm my property.
DWF
That was the Original Poster. This is different. JimHe said he had a survey pin by post.
That was the Original Post. This is different. JimHe said he had a survey pin by post.
Paint the PVC with Plastic rated silver paint and orange top. Mimicking steel! JimI like that answer. I'd prefer steel pipe, but plastic is a lot cheaper and lighter.
The fields next to us is not that big. infact the neighbors farm all together is about 80 acres and that is broken up into 4-35 acre bits when you account for all the ditches which i suspect he is paying rent for.I can see this happening farming in the suburbs, but with 10,000 acres, what’s he doing up against the property line?
I wondered about that. I know them and don't think/pretty sure they will do a darn thing.Xwhatever, I would be talking to the neighbor not the renter. Driving an iron below grade is also a great idea.
spraying chemicals on you is just as bad, especially if close to the house. its your yard so if you want to mow their corn down you have every right to. problem is YOUR yard is dead now. next year they may come over another 3 feet.I have a new farmer next to my property that my house is on. This spring when it was sprayed, my grass got killed about three feet, OK, but my house is close. When they sent the field cultivator to prep for planting, he saw the dead grass so that got worked up and seeded to corn. Now I should talk to someone to get this nonsense corrected. I have been here 7 years and the other farmers never sprayed my grass or tried to farm my property.
DWF
Having hit my share of bright orange tile intakes that won’t help much they are used to judging how high the boom is to pass over or straddle between the wheels. It’s more likely to get sprayed over the top and get the weeds killed so that’s maybe a plus.How about a plastic pic pipe to replace the post with a orange tile intake slid over the top, easier to see, and maybe the operator will think its a tile intake and keep more distance?
I appreciate what your saying bc but anymore farmers or hired help take no pride in their work. I rented my farm out 4 yrs. ago but when I was farming I rarely used a disk but when I did I went real slow along road ditch so I wouldn't throw the slabs down the ditch. Likewise the neighbors fence or lawn. When going around a post or hyline pole in the field if I saw I was 6 ft away I turned around and made another pass only closer. If I was to close and saw I was going to hit the neighbors corner post I backed up and moved over. Teach that high school kid to slow down along the neighbors and if your to far away make another pass only closer. But I suppose your right. If the kid running the disk slows down his boss with the 36 row planter will run him over. All anyone cares about anymore is quantity not quality. Enough said, I have to go out and feed my chickens and I assure you I will do the best job I can.First of the summer. Probably a high school kid on a 30 foot disk. Hard to judge sometimes. Either they get too far away and leave a strip of 6 foot tall weeds along the property line or they get so close that they push a ridge of dirt along the line making it hard to mow if you have it in pasture. If you had a fence there then more problematic. If you plant on your side then both have to watch it. Just keep a post out there to protect survey pins so the kids and grandkids will know when you are long gone.
