New Avery update
grandpa Love
The outside cleaned up nice, maybe too nice for "used red" 😜. The motor ain't pretty. Several gallons of water in the oil pan. But by the end of the day we had the head ( sheet metal,gas tank,alternator, oil filter housing,air breather, carb , manifold and upper radiator hose had to come off,too ) and oil pan off and the pistons out. Bearings and rings look decent at first glance, obviously we haven't had time for a close inspection. None of the valves would move at first, plenty of Free-All and they all came open 😲. We will keep spraying and tinkering with them,I believe they will be ok. We will hone the cylinders today and figure out what parts we need to order. We do enjoy a good challenge. Hopefully any naysayers will just enjoy my update. The oil pan , valve cover and manifold gaskets were missing,just a huge glob of orange gasket goop.🤬. Crazy stuff you find. No matter what parts we buy new or reuse, whatever work we do, we will fully disclose to anyone who buys this tractor......if we sell it 😜
That had to be a fairly resent internal flooding. I don't see the pitting normally found when flooded for years. Have you checked the cylinder bore for out of round? I would love to see the valve seats after the valves have been removed. What did the bearing shells look like. Just wondering what condition it was in when retired to window dressing.
We have found a broken valve spring, possible that's why it was parked? Everything else is looking good.
Kevin, that is a good looking Avery. Is it an "A" or an "R"? I think the "A" only had a 3 speed transmission and the "R" a 4 speed. I am not exactly sure since I got rid of my Averys about 2003.
Avery got bought out by Minneapolis Moline and they continued the line with a repaint using their signature yellowish gold and relabeled the "R" as a "BF" but still a two row. They kept the one row"V"series as the "V" and just painted it MM colors. For a while the "V"'s were painted either red or gold. I had a "V" and an "A" over the years.
The Hercules engines were really tough, but parts were real pricey. The serial number should be stamped on top of the right frame rail close to the transmission.
