tomstractorsandtoys
It is interesting how much equipment has been set up incorrectly. I recently bought a Deere 237 mounted corn picker that was sold new on a 3020. When I went to put it on my 2510 I realized the row unit mounting toggles were in the wide position which was for two cylinder tractors as they need to be wider for clutch clearance. You can move your wheels in a little more in the narrow position which will help with knocking over corn in the next row if the planter driver cheated some on row spacing. When I hear people complain about an implement not working I often wonder if was setup correctly by the dealer and if it is adjusted properly by the owner. Neighbor had a disc he bought new that always threw a center ridge. Turns out the rear gang assembly spacing was wrong. Tom
