First, the good:
As mentioned last, it's first job was hauling wet (with all the rain) bedding and manure to a somewhat soggy field 3 miles away (part of our leased land which tends to be a bit dryer than ours). I got half the 50bu ground drive spreader unloaded on old weedy sod on the first trip, when the draw pin started pulling weeds and mud, and forward motion ceased. Pulled the pin and the H stirred mud for another 20', but walked away. Call me impressed. If I'd tried that with the SA, it would still be sitting there. The spreader is still in the field because we've gotten another 2+" of rain since, lots of full overcast when it isn't raining or drizzling, with more rain forecast for the next 3 days, and the field owner doesn't want things further torn up getting it out, even though the plan was to fertilize, disk, and re-seed for hay/grazing. The good news is only about another 7 loads needing to go...
Other good things: Touch the key and it purrs. Road gear just flies. For a 28hp tractor, it pulls the hills really well. Steers great. Ride is downright comfortable. I am really, really going to like this tractor, especially when I get a 3pt on it, and eventually, live hydraulics. Anyone out there have front cover and pump drive gear parts for a 300/350 they'd be willing to part with? Probably not.
Now the problems:
It pops out of 4th, especially when going across a field at a high idle (pull/push surge through transmission). Shift detent seems to "click in", but the shifter also hits the 'dash' pipe in 4th. Any suggestions?
Right rim clamps don't seem to be clamping tight as even after torquing with an air wrench, I can still hear a slight 'chuck' to that side in 5th. I'll pull them and use a mill to evenly take a bit off the flat faces.
I moved the hydraulic line from the front cylinder to the back to run a mo-co lift cylinder (as a one way), and noticed that when I pull the liftall rod, the PTO shaft runs. Not sure if it's fully powered (enough to run equipment), but it does seem to have substantial torque. What's up with that? Got the manuals yesterday and it doesn't mention anything of the sort.
Now the problems:
