Paul 300 U
I've had a heck of a time finding a cylinder for my McCormick loader that matches my specs. It's my first time doing this and Ive heard here that it's pretty common. I ended up spending a lot of time focused on bore, stroke,length and fitting the loader and bucket brackets. The last cylinder was about 3 inches short and required modification of the brackets or the cylinder. My new cylinder came in and it looks like a good fit. Bore, stroke, extended length are right on. It looks I'll only need to do a small amount of grinding, adding bushings and washers to get a good fit. My question is how do I go about attaching the hydraulic lines. The ports are much smaller on the new ram. I'm hoping this can be overcome by buying new
fittings. I'm looking to learn whether this is correct and how to go about the process. Thanks for the help as always. Paul
