Ilmontgo-HT
Hey everyone. I'm glad to have found this board and Hoye Tractor. A friend and I just went in on a YM1500D together. It has a loader. It has the loader valve with the two levers for that and a third lever for accessory hydraulics at the loader. The day before we saw the tractor, another person was looking at/operating it and apparently all the hydraulics just suddenly stopped working with no fanfare. Both of us being somewhat mechanically inclined and me having some experience with small Japanese diesels, we bought it as-is at a discount.
So with the engine running, there is no lift on either the loader or 3-point. The pump and lines aren't heating up at all or making any noise. The previous owner had recently had most hydraulic lines replaced and then he moved a lot of dirt successfully before listing it for sale. We did some checking (cracked open lines one at a time and cranked the engine) and there is no pressure or flow out of the pump. We haven't drained the hydraulic reservoir to check the pickup screen yet but will do so. The hydraulic oil is full on the dipstick.
We removed the pump to check the coupler. All mounting bolts for the pump were barely hand-tight, there was only half a gasket behind it and a tiny string of silicone. The nut that secures the coupler was also loose, backed off maybe a couple mm from being seated. The pump turns smooth and from what I can see down in there, the gears seem to mesh fine.
Do you think maybe the test-driver closed the 3-point lock-out at the wrong time and blew the pump? What <I><s></s>would<e></e></I> happen to the pump if someone did this? Mechanical damage? Is it possible that the coupler nut backed itself off and allowed the coupler to spin independently of the pump? We've been waiting on time and materials to put it all back together with the re-tightened pump coupler, new gasket and o-rings. Also, does anyone know the full hydraulic system capacity with a fluid change?
