First post here, forgive me if I don't speak correct tractor talk. I am a Model T Ford guy for almost 40 years and know them much better. I just bought something I always wanted and that is a ford "Golden Jubilee". Before I get into that I have had Farmall cubs for many years (a 1963 low boy and a 1947 standard) and have been around the block with splitting, clutches, rear seals, falling tractors while putting on weights...plow snow, garden, mow.
Now for the NAA, wanted one for a long time but never really looked hard. One jumped up on me local and the right place at the right time so I bought it (and drove it home). Seems to be a good piece and I am pecking away at it as I have time. Did all the ignition first then fluids, replaced broken manifold and adjusted brakes but that all needs replaced.
Here is the big question before I go on any longer...this tractor has no stamping over the starter (wire wheeled it all off) for a number but there is an oval brass plate on the left side below the steering sector that reads NAA00018. At the top of the block on the left side it is marked *34. Is this a really early Jubilee or am I looking fooling myself?
Regardless it is a good running tractor with excellent sheet metal. When I get the brakes rebuilt and front wheel bearings and races I will knock it apart so it can be red and grey again instead of blue. I have used it to spread 30 yards of gravel in the driveway and my only complaint is I got done too fast.
Any thoughts on these numbers?
Regards,
Tim Moore
Regards,
Tim Moore
